Results 1 to 3 of 3
Thread: Scanner With Tq input not outputting Hp correct
    Dec 2012
    235
    I have an Mpvi2 that has a 0-5v output from the Dyno that goes into the input of the Mpvi2, that will output Dyne Tq. So I can have actual Dyne Tq logged into the Scanner. From there, I take the reported ([Dyne Tq. x Engine Speed] / 5252]) to get Whp in the log. But for some reason the math isn't adding up correct. How can the basic math be off? Here is a screenshot.
    May 2018
    27
    I have a similar problem with an AEM wideband AFR meter. I transform the 0-5v signal to AFR in the chart field and it display a proper AFR in the Chart section. However, when I attempt to chart this over time, the chart displays the 0-5v values and not the transformed values. Makes comparing commanded AFR versus Actual AFR difficult.
    I have reported this as a bug but haven't received any acknowledgement from HPTuners. Piss poor customer service.
    You may have to define your dyno torque as a math parameter referencing you 0-5v signal instead of using the transform function.
    Dec 2012
    235
    Weird thing is, It is a math that I did for torque that is being displayed. So when I take that tq data, multiply if by rpm and divide by 5252, that simple math doesn't come out correct for horsepower. It's like the simple calculation is not right.
