Spark questions
I have a 2017 mustang 3.7L has 52# injectors on e85(measured e90). I have adjusted spark across the mbt and borderline tables however the knock sensor is adding more timing and hiting the pre ignition table since its the lowest. I have not adjusted it from the stock values. Should i raise the pre ignition table?
you should not have to increase the mbt spark table
yes you can max out the pre ignition spark table to null it
Thank you. So just increase borderline tables and leave mbt tables stock?
Max the Pre-Ignition table out, 63.5 the whole table. MBT has different timing on fuels with different stoichs and octanes.
