Thread: HELP!! 2008 4.3 to 4.8 swap still wont crank after vats delete
    Apr 2019
    Anniston, AL
    10
    ok customer has a 2008 Silverado 4.3 truck converted it to a 4.8. They swapped the harness, computer, column and bcm I deleted the vats and I did write entire still didn't work. Even b4 tuning reduce engine power light was on. there is no power to the fuel pump the harness doesn't look like it had a fcm to it so I don't know if that would be the issue or not. you can straight wire the fuel pump and you can here it kick on not enough to crank it tho. I have disabled everything on the security side that could hold it back unfortunately I cant get paid if it don't crank. Any knowledge would help never ran into this issue.
    Jun 2010
    293
    trouble codes?
    7,617
    Whatever is wrong with the throttle is causing the no-start. Ignore everything else until you can get the pedal to control the TB with key-on.
    Apr 2019
    Anniston, AL
    10
    wish I would of wrote down the codes it had. Had a code for key but the key was for the column they took. I think it has something to do with the fcm. I read that it can be bypassed but you have to use aftermarket fuel pump. im catching up with the guy this weekend to see what else they may have done.
