I started modeling the VE table the other night from the stock tables. I went ahead and multiplied the entire table by 1.15 before switching to all VE. Previously it was an all MAF tune. I'm logging stft in a VE histogram MAP vs RPM I want to say.
Anyway, during closed loop all of my trims were very negative, meaning that I have too much calculated air in my VE table. Well, I have went through and for the most part adjusted the airflows pretty close on trims and the one thing that sticks out is they are lower than the the initial stock VE table. I'm only doing 0k-4k but for the most part across the board they are lower, is that normal? Cam is a 232/241.
Also, redoing my MAF which was done with a wb a few months ago. During CL the trims start -1 and progressively get higher towards -10 at 6500Hz. Could the initial wideband have been that far off?
