Results 1 to 5 of 5
Thread: Need Help ASAP 6l80 swap and wont start
    Apr 2020
    Saint George UT
    8
    Hi Guys i bought a brand new 6l80e for my LT83 5.3
    The transmission had a blank TCM so GM flashed it with the stock program
    but in doing this had to also flash an update into my ECU.
    After he installed everything the Engine cranks but wont start.
    13,559
    Possible that you are running into a VATS issue now.
    Spray some brake cleaner in the throttle body, if it starts and runs on that you have no fuel.
    Apr 2020
    Saint George UT
    8
    Have turned Vats off in the new tune
    13,559
    I can't help much without the tune file and a data log of you trying to make it run.
    And was the VATS removal done with a write entire or write calibration?
    Apr 2020
    Saint George UT
    8
    Ok got it started and moving. No reverse but reverse lights come on also on the dash.
