Results 1 to 3 of 3
Thread: Cruising afr Mustang 3.7 2015
    Sep 2019
    11
    Where do I change the are for idle and cruising? Car has 90 lb/hr injectors, double fuel pump. The car is boosted but my afr's are way too rich at idle and cruising. I changed the flow rate for the injectors and wot lambda for .76.
    Sep 2019
    11
    Someone please?
    Oct 2016
    Poland
    1,750
    This car is MAP so you tune fuel trims with speed density. Honestly I never had to change it that much as long injector data is correct - double check that first.
    PM me if you want a good boosted tune for S550 V6.
