Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: 10r80. Raising shift points
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    495
    Quote Originally Posted by Nitmer View Post
    I?m having this problem too with my 10r80.
    It will not up-shift and go into the next gear at WOT. Then limp mode for a second or two.
    How can I fix this?
    start a new thread, post your tune and a log of the issue
    May 2020
    34
    Quote Originally Posted by ghostofnyc View Post
    got a few questions
    Sep 2018
    Knoxville, TN
    40
    2020GT A10 trying to raise shift points
    Trans will hesitate for a second or two before shifting like hitting a limit. Don't have a log to post.
    Jul 2016
    495
    Quote Originally Posted by Volstang View Post
    Part throttle leaving a stop or at wot?
    What drive mode?
    From your statement about the problem it seems like you could get a log of it very easily. (with all of the necessary "source" pids)
    Edit: I think I see your problem, try this E85 TB Rev3 RPM Anti Sft Off - fix.hpt and if it fixes it please report back.
    There are more things I see need attention, maybe you should start a thread about tune help and post your file regarding e85 set up.
    Jan 2018
    200
    reviving this thread: will be using this file as an example;stk.hpt
    navigate to transmission>general
    most tables will need to be modified appropriately for your targeted shift points in this tab.
    start there and raise your RPM, Elements, OSS, and other related limits there. Raise to a reasonable number for the targeted shift points.
    Now navigate to Transmisson>shift Scheduling
    here you'll be modifying the OSS map and the desired shift points
    Make sure your OSS map matches your desired wot shift points: I usually start my wot shifting strategy around 80% ACPP
    that'll get you started: also don't forget to adjust tq management!
  6. #26
    Dec 2019
    27
    here is the file and log currently for some reason still not shifting as commanded.
    lucifer trans.2.hptLucifer 1.hpl
  7. #27
    Jan 2018
    200
    your OSS cal is wrong, you're about 200rpm high on the base and 300 high on the sport maps, You're also not logging much in the line of transmission data, I would add-in OSS', shifting schedules, TCC rpm, and so on.
  8. #28
    Dec 2019
    27
    for some reason my stock file is showing shifting at way above what stock is here's a glance Lucifer Stock.hpt im using 10R80 rpm and TCC Converter (reverse rpm calc) (1).xlsx
  9. #29
    Jan 2018
    200
    looks right on target to me for OEM, I'm not sure why that was done, I doubt its a translation error by HPT however it is the same across all mustangs so lets assume its on Ford's end. If you make your own calculator you'll see that the values you get are different from the cal your using. I used that one for a short time as well and didn't get anywhere so I made my own. There is a great patent out there I read about understanding transmission ratios and their function. If you do your research you'll see an easier way to calculate OSS based from known transmission ratios and engine RPM. From there Excell is your friend.
