Hi guys, I would like to let my active valve exhaust open 100% all the time like in track mode, I found it in system but I don't know how to change it. can you help me?
Make the whole table 100%
when you say whole table you do mean bank 1 and 2 in normal and sport? And also in drive by
What is Drive-by?
I'm new and confused.
Is that so you can quiet the exhaust down so you can do a drive by shooting in Da Hood??
If you want to set the exhaust to 100% open at all times in all modes which I believe is what the OP wants then set all the tables default positions and and all the bank 1 & bank 2 tables to 100%, including drive by. Set your normal min speed to 0 mph and your normal max speed to 255 mph. This should leave your exhaust in the 100% open position at all times from idle to full throttle at all speeds.
