Results 1 to 10 of 10
Thread: 2012 GT A6 cant get the car shift 3-4 and 4-5 wherever i want need help
    i cant get the car to shift around 7200-7300 in 3rd to 4th and 4th to 5
    already try anticipated shift enabled or disable
    max accel from 0-100
    tq based shift enabled or disable
    try to lower or increase mph
    try to lower or increase rpm
    NV base is change to reflect 3.73 gear
    we try 2h00 on the road
    need some help or im missing something
    19-09-14 17-06-16.hpl
    Nov 2009
    All Around
    3,149
    how to you want to reach 7200-7300 rpm when your rev limit is at 7000rpm?
    I upload the wrong tune
    It got the same trans setting except the revlimit at 7900
    files attached
    files attached
    Oct 2016
    Poland
    1,731
    Cool now we need a log with that problem you have.
    log is in the first post.
    i cant get the car to shift at 7200-7300 in 3rd and 4th.
    once the 3rd shift, 4th shift 2-3sec after...
    Oct 2016
    Poland
    1,731
    It's not a limit, it's short-shifting.
    Your spark enters BASE briefly on shift, your TCC is not responding correctly - you need to fix that.
    Raise your neutral RPM limit - might help. You still have some limits to raise in your trans - look carefully.
