Results 1 to 5 of 5
Thread: negative IVT values?
    During a WOT pull today, I Logged very negative IVT values. The temps rose like normal, then dropped to -300s. This obviously threw off the fueling as open loop base tables are based on IVT values. Has anyone seen that before? How to fix??
    Also, during same pull, I was trying to merge to fast lane on highway. AT WOT, TPS and APP matched, yet it took almost 3 seconds for the truck to start accelerating. I almost got nailed from behind bc it took so long for the truck to react..
    Is that a driver demand table adjust, or a virtual torque table adjustment. All the data is also in the attached log, as seen when there is a big jump in RPM. Thats alo when I saw negative IVTs.
    I attached the log as well
    Oct 2013
    211
    IVT is a bug in the scanner, there are a couple threads on it. You are logging 2 wideband inputs and its throwing off your eq error, delete the one that is reading 13+ lambda and go dial in the fueling. it probably feels slow because you are at .94 L at WOT.EQ ERROR.jpg
    Mar 2010
    Texas Hill Country
    3,299
    have we logged IVT on different scanners? How do we know it's a bug in the HPT Scanner?
    Many IVT tables have the high load negative values populated uniquely which leads me to wonder if it is a bug or some intentional and mysterious coding from GM.
    of course it's probably just me. I haven't logged IVT in another scan tool.
    Mar 2010
    Texas Hill Country
    3,299
    I am aware of past conversations about it. Doesn't answer the question.
