Thread: aem 30-0310 afr error histogram
    ive got my WB connected via CAN through prolink and it works fine, I however cannot afr error to log in my histogram on a p11 pcm. Do I need to change the variable in the maths to my widebands id? How do I retrieve the ID for the wideband since its on can? Thanks!
    Nobody? I?m driving myself crazy with this damn thing
    Aug 2019
    Can not help with CAN bus but can confirm it is simple to use analog with the 30-0310 and get it to populate the histogram.
    Prolink red wire 2 aem white wire and prolink black 2 aem brown, add the aem to the channel lists and translate it to EQ or AFR
    I do however have the pro license.
    I have pro feature set and the canbus setup works great no offset voltage to deal with etc. I cannot however get afr error to log in my histogram.
