Results 1 to 8 of 8
Thread: 2007 Crown Vic Failed to Read
    Aug 2016
    15
    Equipment used MPV1 using 4.4.4
    Here's what I'm seeing, any help is appreciated.
    Mar 2010
    New Orleans, LA
    630
    did u update your mvpi1 ? mine staryed doing this after that last update
    Aug 2016
    15
    Quote Originally Posted by decipha View Post
    Not that I'm aware of. Did you have any luck trying to resolve the issue?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    X11 errors can be due to several reasons
    1. VPP chip in MPVI is going bad/has gone bad
    2. not cycling the ignition when prompted
    3. issue with the ignition/ignition wiring to the PCM.
    Aug 2016
    15
    Thanks for the response.
    1. Still works in my 08 Suburban
    2. After cycling it reads: "controler unlocker: timed out"
    3. Power and grounds have been confirmed
    HP Tuners Support
    (foff667)
    28,265
    suburban isn't VPP and doesn't require the chip to be functional.
    Aug 2016
    15
    Bummer! What are my options from here? I have $200 worth of Ford and Dodge credits on this cable yet.
    Aug 2016
    15
    Even after the cable was fixed it still doesn't work. Only the MPVI2 will connect. After all the drama the switches to turn on and off the VATS system failed to work. All I needed to do for the runstand that I had build was to disable anti theft and unfortunately HPtuners doesn't support this ecu. Had to outsource SCT tuner and it did the trick.
