Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: GMC Sierra Whipple part throttle out of control
  1. #21
    Apr 2023
    6
    any more updates on this? same issue, whipple sends the lt4 map now.
  2. #22
    Dec 2022
    7
    Whipple tune aren't good.. don't waist time and money. Get a good email tune or dyno. I finally got my tuned through email and it drives good without any issues...
  3. #23
    Nov 2006
    2,745
    Do a search for adding a SCIAP sensor. It makes a tremendous difference tuning these out.
    We have a pigtail kit.
    Tuner at PCMofnc.com
  4. #24
    Tuning Addict
    Jan 2015
    6,815
    Does your kit include the wiring and instructions on how to wire it into the ecm? If it does I'm sending my customers adding blowers to y'all to get these!!!
    ~Greg Huggins~
  5. #25
    Nov 2006
    2,745
  6. #26
    Tuning Addict
    Jan 2015
    6,815
    OK, sending the link to a gent in Canada right now as he's doing a blown cam swap into a jeep. Already told him he really needed to do this. Nice to know there's a simple kit for it now.
    ~Greg Huggins~
  7. #27
    Apr 2023
    6
    i dont have surging, its a sudden 100% throttle at only like 50% pedal...
  8. #28
    Tuning Addict
    Jan 2015
    6,815
    You can often fix that in the DD tables. Take a bunch out and keep things smooth. I often have to do that for blower installs. Usually lighter throttle though for the drive through window or stop and go traffic scenarios.
    ~Greg Huggins~
  9. #29
    Apr 2023
    6
    take a look if i did this right lol
  10. #30
    Tuning Addict
    Jan 2015
    6,815
    You've got a couple of codes you might want to check into. Might need a new pedal from the looks of it. Think there was an update for flexing too.
    ~Greg Huggins~
  11. #31
    Quote Originally Posted by sandworks View Post
    I still stand by that SCIAP sensor is what you need.
    The ECU does not understand that it has a supercharger attached.
    It believes that 50% Demanded torque roughly equates to 50% throttle
    In a supercharger case, this results in no vaccum and then all the boost.
    The computer then in some cases shuts the throttle because the actual torque is way to high for the pedal demanded torque.
    With the SCIAP sensor, the ECU can modulate the throttle and torque based on the amount of air pressure just behind the throttle blade
  12. #32
    Apr 2023
    6
    i can sure try it, i just noticed my codes lol,, but its a pita to drive right now... pulling out in the street and it basically does a burnout for 2-3 seconds.. not real safe
  13. #33
    Nov 2006
    2,745
    Yes. This is what the SCIAP sensor will fix. IT makes a huge difference.
  14. #34
    Apr 2023
    6
    Any one have alittle more detail on this install? Thanks
  15. #35
    https://forum.hptuners.com/showthrea...cillation-help
