6.0-ls2-t56-headers-lsa supercharger-12psi-90lb injectors, twin aeromotive e85 fuel pumps with ls1 411 pcm- cable driven.
My car was running perfect and so I wanted to switch to e85. (only e45 in there right now, put 10 gallons of e85 on top of a few gallons of 93). I had a 2002 camaro tune file. So I then installed the ethanol sensor and wired it into the pcm. I then loaded a 2002 suburban flex fuel tune file. I copied everything over exactly from the camaro file. It started right up perfectly and idles well, not perfect but within the range its supposed to. The issue is once I give it throttle it goes up 1600rpm and goes max lean and falls back down to idle. does not die.
ive tried my stock ve table. ive added 30% to ve above idle .nothing
Any thought or help much appreciated! Thanks
