I know what the base tables do - 2005 Corvette E40
If I want the base table to dictate 100% of the timing pull/advance based on intake air temp and coolant temp, should I just set the multiplier tables to 1.00 across the board?
Thank you!
Thank you!
05 C6 TT
02 TA: 8.58@157 Radials, N20
Yeah, 1.00 would mean it would pull the exact value you have set in any given cell.
So... if 1.00 means "use whatever's in the base table", wtf is happening in the multiplier cells that are set to 0.00? Does that mean it ignores what's in the base and makes no correction from the main spark tables at all?
Pretty much, because that is how the table operates.
It's multiplying the number but whatever number is in the multiplier. I really only see the 0.00 value when it's way low in the rpm range though.
yea, if you set the multiplier to 1.00 it will read whatever you write from IAT or ECT tables .
