Results 1 to 11 of 11
Thread: best wideband to use for street tuning
    Mar 2019
    40
    just wondering what would be the best wide band set up to tune with a MPVI2 with out prolink?
    Waldorf MD
    774
    AEM 30-0334. OBDII Wideband. Vehicle needs to be a 2009 or newer model (For GM at least). What are you tuning?
    Daily Driver= 2003 BMW 330xi
    Mar 2019
    40
    ya everything ill be tuning is 16 and newer
    13,565
    Quote Originally Posted by jaydubb71 View Post
    Minor correction, the vehicle could be as early as a 2007ish depending on model. The NNBS GM trucks started can-bus in that 2007.5 year, anything else running a E67 or E38 from an early corvette or something would be the same as well.
    Waldorf MD
    774
    ^^^ Thumbs up!!! Great to know!
    I use the obd2 aem and it has been amazing. It was a great starter for introducing someone like me as it is super user friendly and works great with the vcm scanner
    7,650
    I thought the 0334 worked with any GM that needs the CANDi module, and that's a whole bunch of stuff, but not everything, starting in 2005ish?
    Dec 2018
    7
    This is great info for me too as I am installing my LS into my car now and it is running an E38 ECM.
    I have a follow up question to this. Would you still run narrow band O2 sensors and the wide band sensor(s)? Or would you replace the narrow band sensors with the wide band sensor(s)?
    I am asking because I am finishing up the wiring and have headers with the O2 bungs installed already. I was thinking that I would use these for the stock type narrow band sensors and add a new bung in both banks just after the headers in the collectors for the wide band sensors.
    Learning a ton and looking forward to tuning with the HP Tuner Pro.
    Cheers, Brew
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    wideband is for tuning purposes, not for replacement of narrow bands
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Dec 2018
    7
    Thanks mbray. Does that mean you completely remove them and plug the bung when not tuning?
    7,650
    You can leave the WBs in all the time, BUT, they must be powered up and operating. Running the engine with the sensor installed and the gauge/controller switched off will kill the sensor right quick like.
