A lot of you have asked to see the new GT500 file. Here you go.
The TCM for the DCT is still being worked on.
Regards,
Eric Brooks
HP Tuners
Regards,
Eric Brooks
HP Tuners
Eric Brooks
HP Tuners, LLC
Is it normal to require connection to the MPVI2 every time you open it?
Also noticed a couple of the mapped point tables were bottom up versus top down. One had the axis populated with ???.
My Whipple calibration uses valve events in 360 degree range, this looks to use 720 degrees for the full cycle, is that just due to the calibration?
