Results 1 to 10 of 10
Thread: Mustang 3.7 turbo questions
    Sep 2019
    11
    I'm having issues with my 3.7 car goes too lean from 1200rpm to 4000rpm. I don't know how to tune any speed density table at all. Just scaled injectors, decreased spark timing. Tweaked fuel pressure since car has double fuel pump with return system. Can anyone give me a light to try to run the car without lean issues?
    Sep 2019
    11
    Here is my tune, any help will be extremely appreciated.
    Nov 2009
    All Around
    3,149
    why is your stoich set to 22? also you are commanding a lean mix until 4000
    Sep 2019
    11
    Stoich at 22 was the only way to get the afr more or less where it should. Im not sure where I command lean mix until 4000. Which table is that? Thanks
    Nov 2009
    All Around
    3,149
    mahdi95 YOU NEED TO FIX ALOT.hpt
    your injector setting are wrong
    your load scaling wrong
    torque tables wrong
    you need to log mapped points to see where and which tables need to be adjusted based on the set cam angles.
    Sep 2019
    11
    90 lb deatschwerks injectors on the car, not sure if the info was correct. Thank you for the guide, I'm a bit lost on the mustang. Owned a Camaro wasn't too difficult to tune.
    Nov 2009
    All Around
    3,149
    post your stock please
    Oct 2016
    Poland
    1,741
    Set STOICH back to 14, fix your injector data for given return style pressure, you can't rune lambda 0.65 at WOT, each table for spark and torque
    needs LOAD axis adjustment for added boost , your SD model needs attention for added boost, you need to set your inferred fuel rail pressure to
    what you see on your regulator. And many many more.
    We have a very good turbo tune for V6 S550 - email me directly should you be interested.
    Nov 2009
    All Around
    3,149
    mahdi95 lb DW you still need alot of help.hpt
    get it professionally tuned.
    i dont want you to blow it up
    Sep 2019
    11
    Thank you. I guess I'll do that. I just wanted to be able to run the car without lean spikes. No boost on it yet. Ty guys I appreciate it.
