Attached is my Startup tune that I have put together. What i have is
99 Suburban that I put in a 6.0 into. It has been bored .005 over to clean up the walls and I put flat top pistons, gen4 rods, BTR truck stage 2 cam, 799 heads with Manley valves and pac1218 springs, tbss intake, warr throttle body. So far what i have changed is the 2500 stock file i segment swapped the trans to a 4l60e then I seg swapped the fuel info. I went in and turned off the mil lamps for downstream o2, adjusted for my injector size, adjusted for my cyl volume size, changed the tune to work for dual fans, and added 15% to the main ve to start with. I am using info from Chopperdocs youtube vids to start this. Will the be a safe starting tune and am I missing anything.
