Results 1 to 3 of 3
Thread: Need help with 08 GMC 2500 6.0 electric fan swap
    Aug 2015
    1
    I have a 2008 GMC Sierra 2500 HD with a clutch fan. I recently did a fan swap. I bought OEM electric fans and got a factory harness from a local dealer that came out of a truck with electric fans. I thought all I would have to do was plug everything in and adjust the tune. I tuned it to what it needs to be and my fans did not come on. Upon researching I have found that I will have to pin my e38 ecm in pins 17 and 58. My question is what size pins do I use and where do I connect the pins on the other end? Do they go to the relays? If so, does it matter which one goes to which relay?
    I thought that since my truck has fuses and relays for the fans already that I would just be able to plug and play. Thanks in advance for any kind of assistance. I have been looking everywhere and just cannot find much information for my year model and this set up.
    7,607
    7,607
    (click for big)
    Connector Part Information
    OEM: 15499466
    Service: 88988931
    Description: 73-Way F Receptacle 0.64 2.8 Series Sealed (BK)
    Terminal Part Information
    Pins: 1, 13, 24, 30, 32, 50, 57
    Pins: 5-6, 8, 18, 21, 25, 27, 39, 41-42, 47, 49, 54, 65-67 (4.3L)
    Pins: 12, 16, 23, 29, 31, 33-34, 36, 56, 59, 63, 68, 70-71 (4.8L/5.3 L/6.0L/6.2L)
    Terminal/Tray: 33467-0003/23
    Core/Insulation Crimp: H/H
    Release Tool/Test Probe: J-38125-213/J-35616-64B (L-BU)
    Pins: 2-3, 9-10, 19-20, 37, 70, 72
    Pins: 15-17, 26, 35, 43-44, 55, 58 (4.3L)
    Pins: 11, 18, 27-28, 38, 41, 47, 49, 52, 61, 64-65, 69, 71 (4.8L/5.3 L/6.0L/6.2L)
    Terminal/Tray: 33467-0005/23
    Core/Insulation Crimp: J/J
    Pins: 73 (4.3L)
    Terminal/Tray: See Terminal Repair Kit
    Core/Insulation Crimp: See Terminal Repair Kit
    Release Tool/Test Probe: See Terminal Repair Kit
    Pins: 73 (4.8L/5.3 L/6.0L/6.2L)
    Terminal/Tray: 7116-4152-02/9
    Core/Insulation Crimp: A/5
    Release Tool/Test Probe: 12094430/J-35616-35 (VT)
