Results 1 to 9 of 9
Thread: User defined Lml
    User defined Lml
    Anyone have user defined for Lml trucks?
    Jul 2018
    there's more to it than ya think.
    Dec 2008
    Nevada
    4,450
    as mentioned its pretty advanced. i dug into it once and found out i dont have the skill to use it, probably not saying much there but this is what i learned:
    1) you need a hex file for the ecu. this isnt always too hard to get but what is...the decryption file that is required to make it understandable. this is the .bin file that xdf requires.
    2) you need to search and figure out the extra tables you want and then compare them to the available room left in the ecu. sometimes the upgrades just wont work due to lack of data space.
    3) you also need to have tuner pro xdf...i believe its free but you need it in order to make this all work.
    here is the programming link for the xdf generation walkthrough...it doesnt tell you how to figure out anything about 1 or 2 though.
    https://forum.hptuners.com/showthrea...ned-Parameters
    Advanced Tuner Programmer's Avatar
    Jul 2007
    241
    Yes...and LMM. Working on L5P.
    2009 Cadillac CTS-V 196.7 MPH on the Salt
    Superflow SF600 FlowBench -- Superflow Autodyn 30 Chassis Dyno -- Superflow SF901 Engine Dyno--RaceLogic Emulator -- MikiPro Logic Emulator -- ASNU Injector Flow Bench --
    Sep 2021
    Did you ever get a L5P XDF done?
    Open up your wallet. I've heard of 3k to get your hands on that file.
    2006 GTO 403ci lsa heads kooks long tubes corsa ss exhaust OTR intake HPTuned
    2010 GMC Sierra LMM Duramax. Exhaust and tuned
    Aug 2023
    canada
    91
    for the l5p's it depends on the OS. i have built many xdf's using winols.
    Sep 2021
    Is there a how to or something like that to get pointed in the right direction for using winols to make xdf's? I learned SATCOM on the fly, I can probably figure this out with some breadcrumbs
    You will need the SPS bin for the OS you want to work with. Then you will need the A2L for the OS you want to create the xdf for. Get ready to spend some money because an A2L is not cheap. You will also need WinOLS and the plugin for TunerPro.
    So before you create your first xdf you will be about $3000+ out of pocket. And that is for only one xdf. The other will be cheaper though.
