I've searched up and down and can't find a definitive answer. Have a 70 Chevelle what the LS6 drive by wire, with Tac module, pedal and throttle body, wiring harness and ecu from a 2002 Corvette. Trying to find the right file or a way to get it to segment swap to work. Car starts perfect runs great but as soon as I put it in gear it dies. If I disconnect the harness from the trans I get first-year neutral and reverse . Only two codes it's throwing a solenoid A and TCC clutch .Had the same setup with a 5 3 and 4L 60 and had no issues, but I know that corvette never came with the 4l80. What's the best route from here.
