Results 1 to 11 of 11
Thread: Aem 30-0300 issues!!!
    Waldorf MD
    774
    Greetings.
    Bought and installed an AEM 30-0300 wideband. Running HPT version 4.4.4.
    No matter what I do or set it to, be it AFR or Lambda, HPT is not reading the output correctly...
    AFR= Constant 19.18, even though the gauge shows actual AFR
    Lambda= Constant 1.32, even though the gauge shows actual Lambda
    Im so fricken mad. Im going to contact AEM tomorrow and see if they can help.
    Can ANYONE help me with this?
    Thanks in advance!
    Daily Driver= 2003 BMW 330xi
    7,569
    Not reading the output... which output would that be? Serial via USB or analog? If analog what's it connected to? MPVI2 pro or an unused ECM sensor input?
    Dec 2005
    604
    If its the analog output, the problem usually is the Analog- wire not being grounded to the scanner.
    To double check things, a single fresh AA battery usually has a voltage of about 1.6v. Connecting it between the analog input and ground ( with the gauge DISCONNECTED ) should cause the scanner to show about 11.0AFR or 0.75 Lambda.
    Waldorf MD
    774
    Analog. And it's been connected to the prolink via the red and blue wire. Forgot to mention I'm using an MPVI2. I was so upset last night that I failed to mention that...
    7,569
    Sorry, but I have to ask since you didn't specify any of this. You did buy the pro feature set, not just the pro link cable? 'Cause they'll happily sell you just the hardware even if you don't have the upgrade required to make it work.
    Waldorf MD
    774
    Yeah... I have a MPVI2. Pro Set and Prolink. Ive scanned a 30-4110 and a Innovate MTX-L with no issues. Im wondering if the WB is defective. I have tried all combinations of input and offset with no success. The output NEVER changes. CONSTANT 19.18 shown in the scanner while the gauge shows true. ARRRRGGGHHHH! LOL!
    7,569
    Since it's just a normal analog 0-5v signal, have you checked it with a DVOM while not connected to the prolink?
    Waldorf MD
    774
    Not yet. I was in a situation where one wasnt available. I will check it at lunch, if I can find a DVOM here at work.
    7,569
    From the AEM instructions:
    Important Note: If bench testing the analog output outside of a vehicle [or in this case, testing the analog output while disconnected from the prolink], a multimeter's positive lead may be connected to the WHITE wire however the BROWN wire must be connected to BOTH the multimeter's negative lead AND power ground going to the X-Series UEGO device.
    Waldorf MD
    774
    Gotcha. I was going to try that anyway. I will see if I can find a meter. Thanks!
    Waldorf MD
    774
    Welp. The GAUGE is bad. Called AEM. Contant 5.05V output. They are sending me an RMA. SMH... And its BRAND FRICKEN NEW!
