I just registered my MPVI2 on hptuners.com and added my device. I tried the resync interface on VCM suite (which I have updated to the latest version/drivers) and keep getting this message "Resync Failed. 401 Unauthorized". Please help - Thanks.
Means your time settings are not properly set for your region, you will need to fix your time settings.
both time setting is on auto and my location is correct and it still doesn't sync.
still getting the same message. even tried restarting the computer and checking for updates. even when it checks for updates it saids failed 401 unauthorized.
Here are some things you can try https://www.thewindowsclub.com/windo...time-wrong-fix
Thank you. just solve the problem with your indication
