Results 1 to 20 of 34
Thread: PROBLEMS!!!! 4L60E not shifting at WOT
    Sep 2019
    Virginia
    34
    Question PROBLEMS!!!! 4L60E not shifting at WOT
    Guys please help i?m so freaking frustrated with this truck!!!
    It?s a 2005 Chevy Colorado 4x4 I installed a 5.3 LH6 w/ Texas speed cam 212/218 600 lift. The trans is a 4L60E with a 2200-2400 stall. Tire are 33/12.50
    The problems i?m having is the truck will not shift at WOT also it will not go into lock up on the converter, I can command it to go into lock up but when i do it starts to surge. I?ve watched countless videos on YouTube about the not shifting at wide open throttle and I?ve tried them all. I live in Virginia and it?s so hard to find a good tuner in my area.
    Any Help would be awesome
    post the tune
    Sep 2019
    Virginia
    34
    Sure thing, as soon as i get home
    Sep 2019
    Virginia
    34
    Quote Originally Posted by regorih View Post
    post the tune
    MY COLORADO TRANS ADJUST 1.1.hpt
    Aug 2019
    Cleveland, TN
    87
    try using the bluecat trans calculator, can find it in the forums.
    it wont make any shifts at WOT? or just certain shifts?
    you need to be careful applying lockup at WOT, if its not built wouldnt suggest it. but there is a tab in TCC for it. also might want to raise min TCC duty to 90 across the board, and 99 on max. its either on or off.
    Sep 2019
    Virginia
    34
    So I just got back from a test drive. Take a look at the data log if you dont mind. But the truck from a dead stop I floor it and it shifts from 1st to 2nd then gets to 6200 rpm and goes into fuel cut I let out of it and it shifts to 3rd.
    Aug 2019
    Cleveland, TN
    87
    you posted a tune file
    Sep 2019
    Virginia
    34
    first save file.hpl
    second test drive.hpl
    Sorry new to this tuning and logging thing
    Sep 2019
    Virginia
    34
    third test.hpl
    four run test.hpl
    here are a few other runs
    Aug 2019
    Cleveland, TN
    87
    heres an example of my log files
    Sep 2019
    Virginia
    34
    Not sure why mine is not showing the whole log.....
    I'll try again
    Sep 2019
    Virginia
    34
    Sep 2019
    Virginia
    34
    test test test
    Aug 2019
    Cleveland, TN
    87
    you need more channels and longer logs, more info the better
    Sep 2019
    Virginia
    34
    Im not sure what the hell happen to my log files they dont look like they did. Ill have to make a few logs tomorrow and try again.
    Sep 2019
    Virginia
    34
    log file
    I hope this worked. Im not sure what i did last night to VCM scanner but the logging looks way different, I think i'm going to have to reinstall.
    Aug 2019
    Cleveland, TN
    87
    mph would help a bunch. you ever get bluecat software?
    Sep 2019
    Virginia
    34
    Yeah but can only get part of it to open, one part says in need the application, Im no computer guy so i have no idea.
    I'll add the mph to the next log now I know how to post it.....
    Aug 2019
    Cleveland, TN
    87
    i found on the bluecat software, when you unzip it it has 3 file in the folder. i moved entire folder to desktop, then open the exe file from that folder. it need another file to open
    Aug 2019
    Cleveland, TN
    87
    you add channels here when the scanner is connected, the gear with plus sign
