Results 1 to 9 of 9
Thread: Unable to connect to vehicle diagnostic protocol.
    Dec 2005
    Texas
    254
    received error message trying to connect to vehicle with LS1 swap. Harness is new aftermarket, all circuits valid/operational. Tried 2 different pcm's in vehicle and on bench harness with same result. Anybody see this before?
    28,268
    MPVI1 or MPVI2? Either way I'd suggest contacting support if you've already tried on a bench harness I would be inclined to say its likely an interface issue of some sort.
    Dec 2005
    Texas
    254
    MPVI1, I did contact support, first response was electrical interference (noise), suggested using bench harness ( already tried that), second response was to download beta version...I tuned a Gen III truck a few months ago without issue, also tried a Gen IV vehicle and connected without issue..doesn't make any sense why I'm having issues all of a sudden..main intent of this post was to gather info from others who had the same issue.
    28,268
    The symptoms you describe would lead me to believe its a VPW chip issue on your MPVI1, I say upgrading to the MPVI2 is really your only option in this case.
    Dec 2005
    Texas
    254
    recessed pin (C2,19) in the PCM not making contact with connector, explains why I couldn't communicate in the vehicle or on the bench. I pulled the pin back out with needle nose pliers, everything working properly
    28,268
    weird, so was it an issue with the harness or the ecm itself?
    Dec 2005
    Texas
    254
    ECM, I assumed those pins were hard mounted to a board, apparently not
    28,268
    so you had 2 separate ecm's that had the same issue?
    Dec 2005
    Texas
    254
    2 ecms, 2 separate issues apparently...i couldn't connect to my buddy's spare ecm for some reason. The original issue was resolved with pin reposition.
