Results 1 to 20 of 24
Thread: Swap from charger 5.7 to 6.4
    Oct 2019
    10
    Hey, my car is a 2014 charger rt, i swapped my engine from a 5.7 to a 6.4 im trying to figure out what's the easiest way for me to convert my 5.7 tune to a stock 6.4 tune. do i have to copy parameters one by one, or i can just use a stock 6.4 tune from the repository.
    i need help, its a complete stock 6.4 engine, i also got the intake runners to work with an MSD switch so they open up at the same RPM as a stock 6.4.
    HELP
    Mar 2018
    Illinois
    873
    Even if you copy over all the parameters from a 6.4, I can tell you the 5.7 PCM will not report the correct cam angles as it is setup for a cam with an LSA of 114.25 not one with a 120.5 LSA. 5.7 PCM treats exhaust angle of 125 as full advance where a 6.4 treats it as ~135 so you will need to apply an offset of -10 degrees to all the VVT exhaust tables.
    https://forum.hptuners.com/showthrea...l=1#post587987
    Oct 2019
    10
    what if i just get a 6.4 PCM from the junkyard, i found one for a good price. would i be able to use it with my VIN and just program it with HP tuners ?
    Mar 2018
    Illinois
    873
    Not sure if it would work? I would also get an engine harness just to be on the safe side. Might even get the manifold valve to work?
    Oct 2019
    10
    regarding the manifold, i got the MSD switch to operate it. but in the future i might go that route with the wiring harness as well.
    PCM will work but you will need to program the vin and make a few changes with hptuners. harness shouldn't be needed.
    Mar 2018
    Illinois
    873
    So a 6.4 PCM running 6.4 OS can be programmed with a 5.7 vin?
    Mar 2009
    S. Florida
    582
    Quote Originally Posted by Homer View Post
    Love to know this to and if there are any advantages?
    Quote Originally Posted by homer View Post
    so a 6.4 pcm running 6.4 os can be programmed with a 5.7 vin?
    yes
    Mar 2018
    28
    Absolutely. We have done plenty of 6.4 swaps and when engine comes with harness & PCM, we use it. Send 6.4 PCM for unlock and have them write new VIN.
    Mar 2018
    Illinois
    873
    Quote Originally Posted by allpargarage View Post
    I thought the witech stuff would somehow not allow it or the 5.7 BCM would have issues with the 6.4 PCM. I mean, if you look at the tune details in HP tuners it lists the vehicle info which I thought the BCM looks for as well. Thanks for confirming.
    Mar 2018
    Illinois
    873
    Quote Originally Posted by coanan View Post
    One advantage I could think of would be the VVT values would not have to be offset. As I state before, the 5.7 PCM shows full cam advance with and exhaust angle of 125 deg where as a 6.4 PCM sees it as 135.
    Mar 2018
    28
    Just need to set table 13512 to 5.7 so ABS/ESP will be happy. If you leave as 6.4, ABS/ESP light stays on with DTC's for configuration mismatch and will disable.
    Big thanks to Hemituna!
    816
    What about flashing a 6.2 OS into a 5.7/6.4?
    Probably not since the PCM is a different part number I'm guessing.
    Mar 2009
    S. Florida
    582
    Does it matter which vehicle it comes out of as long as it's 2011 to 2014 6.4? Where is it sent to have vin programmed in?
    I found refurbed on Flagship one for 187.00 with vin programmed in, lots of different p/n though. How do you which one is right?
    Mar 2018
    28
    Well we have Witech access to handle things like that. If the PCM is 2015+, we have HP write new VIN during unlock process.
    Oct 2019
    10
    yes, AJ and Hemi Tuner did it for me.
    it's a 6.4 PCM/OS with my VIN
    great guy to deal with.
    Oct 2019
    10
    Exactly,
    thats what happened when i first installed it and ran it. ABS/ESP was off.
    contacted hemituner and he told me to change the displacement value to 5.7 and bam worked like a charm
    Oct 2019
    10
    yes it matter, preferably you should send in your PCM cause of the part number and module number should match.
    what i did cause im oversea i gave AJ(Hemi Tuner) my VIN and he bought me a new PCM then flashed it for me with the 6.4 OS.
    never install a PCM thats not for your model or has different part numbers.
    Mar 2021
    3
    Reviving an old thread because I just did this swap. I installed a 2020 6.4L from a scat pack Challenger into a 2018 300C 5.7L. It's still using the stock 5.7L 8HP70 but with a 1320 torque converter installed. 3.09 differential installed. PCM is a new unlocked HPT unit. I flashed in a complete calibration from a 2019 1320 Challenger and the car runs and drives fine under light throttle, but under WOT the PCM never gives me full throttle except for a few blips after shifts, never makes full power. Appears to be torque managing itself down. When this happens, the Throttle Input PID says: Transmission, and when I momentarily get actual WOT is says; Pedal. I take this to mean the transmission is torque limiting it. No faults from the transmission or engine that would limit power.
    My question is for any of you who have done this swap, did you have any transmission issues like this afterwards and if so how did you solve them?
