Results 1 to 3 of 3
Thread: Flex fuel conversion on gen 4
    Feb 2019
    44
    Is it really worth converting a gen 4 to flex fuel if so how much can you gain
    13,559
    That all depends.
    It's worth a possible 5-10hp and 13ft lbs bump on a stock engine, even GM claims that when they rated some of the GEN 4 LS V8 engines. Then if you tune it even more with E85, there can be more gains to be had on a stock engine.
    It would really shine on a modded engine with a camshaft or something along those lines. Also if the fuel is much much cheaper than premium 91-93 octane (if that is what you ran) it could save you money if the gas mileage hit is not a factor.
    Feb 2019
    44
    That all depends.
    Thanks , i guees i will try the conversion more interested on the performance more , and if you can save some change thats good to...
