Hello,
So i just finished a few upgrades and I've been watching goat garage, I followed rinkrat456's idle tune write up. I did both these as best i could, But i feel its not even close. Looking for guidance on where to change or where to make more changes
I'm wondering if some people can look at the logs(idle and tune both attached) and the tune I've done. Ive mainly worked on idle and light throttle cruise.
1997 Corvette with LS1 6MT
-Stock bottom end
-5.3L 243 heads ported,bowls blended and exhaust polished with intake golf balled, Using stock size valves.
-.051" head gasket(Both heads and block were NOT milled. 10.9:1 compression ratio i've determined)
-BTR .660" dual springs
-comp cam 7.300" push rods
-Lunati street series link bar lifters
-BTR stage 4 N/A cam.
-Arp head studs
-Iwis timing chain(Dot to Dot)
-stock headers for now, I do have LT on the way.
-42lb green top ford injectors
-walbro 400 pump with return fuel system(stock 97 set up)
-Wide band in PS manifold 3" from stock 02 sensor.
-Hp tuners with wideband tied in thru ac pressure.
Any help would be appreciated.
