Results 1 to 6 of 6
Thread: dd149mm maf transfer has too many cells
    i have 30 cells on my maf table but the transfer data sheet has many more. it has 7 cells at .012v with stepped airflow #'s but counting that one cell, the sheet has 39 cells to reach from .012 to 5v. i cant add 9 more cells so how should i scale this ? i removed some and interpolated between the ones removed but the final line is less than desireable. dunno how to use excel or i would try an devise their formula. anyone run one of these that can help out ? attaching the maf transfer data
    Transfer_Function_H149mm.xlsx
    Jan 2013
    Hawaii
    2,101
    I converted it to period and lb/min for you.
    Choose any 30 cells that will cover the airflow you will see in your application best, they are all just points in the over all bigger picture.
    I did that earlier but the overall curve had ups and downs after interpolating The spots I deleted. I was thinking it might cause issue
    Jan 2013
    Hawaii
    2,101
    You have more than 30 to choose from, you shouldn't have to be interpolating any cells.
    My bad, I meant smoothing. I loaded it and picked the cells to lose and I must say I was surprised. I was pretty much within 5% error on a light test drive pulling up to 3500
    I just wanted a smooth transition from cell to cell.
