Hi all. If I am running an all stock LS3 on an E67, and copy the tune from the repository for the crate 6.2L 430hp motor, yet I am running the higher flow E85 truck injectors, will the appropriate change in the injector flow data area take care of this difference alone, or would you expect a lot of tables to be out of skew, and I should really just get the LS3 injectors to simplify things?
I have an L9H intake with injectors and throttle body I hope to use on the build.
Thanks.
