Results 1 to 9 of 9
Thread: Is there a way to run gen2 engine with gen1 ecu without cam and follwer change?
    Nov 2010
    Finland
    249
    Gen1 engine got wrecked and gen2 engines are available. Is there a way to control cam timing correctly on gen2 engine with gen1 ecm?
    Senior Tuner CCS86's Avatar
    Nov 2017
    Austin
    1,089
    The general consensus seems to be "no".
    But I'm wondering if that's just because it isn't "plug and play". Mechanically and electrical connector-wise it seems like they bolt together, judging only from stories of people who then couldn't get rid of PCM error codes after running it this way.
    Very curious if this can be handled in the tune, because I want to build a new engine for my Gen 1 car in the near future.
    Oct 2016
    Poland
    1,738
    Quote Originally Posted by Tapi View Post
    Yes without any problem - you just need to time the chains a bit differently.
    Nov 2010
    Finland
    249
    Interesting, could you open this a bit more?
    Oct 2016
    Poland
    1,738
    Sure, ECU is 100% configurable for this mod - I did some tests. The same way you can run GT350 engine in GT.
    Gen 2 has a different chain timing events - banks are spaces differently, further apart like one complete rev more. You fix that, enter gen 1 data and it should work.
    But we never tried this way, not sure I even want to take this route. But IMHO 100% doable with some persistence.
    The easiest way to do this - done and confirmed, lots of swaps documented on FB groups, confirmed personally.
    -buy 2 gen engine
    -swap cams with phasers/chains
    -time your gen 2 like gen 1
    -good to go
    Nov 2017
    Austin
    1,089
    His whole post is centered on not swapping the cams and phasers though.
    Mar 2010
    New Orleans, LA
    630
    x2 that was rather useless
    theres a 2 sided answer to this
    is it possible? yes, all you would need to do is compare the cam sync and controls of the gen2 profile and copy it to the gen1 strategy
    is it worthwhile? not really. It would take someone that has a complete disassembly of both strategies to fully understand each cam types code and has the free time ability and motivation to manually cut and splice the differences over.
    its extremely time consuming and the cam sync routines are a muther code wise
    on the plus side coyotes have so much free memory a complete copy and paste could be possible with just addressing timers flags and fault code lookups updated
    decipha @ EFIDynoTuning
    http://www.efidynotuning.com/
    Oct 2016
    Poland
    1,738
    Theoretically you just change your cam base in tune to 0 and now you have 1 gen timing - as mentioned 2 gen timing travels 1 rev more hence it has 340/369 baseline - and good to go.
    2 gen has a mid-lock phaser for intake cam - not sure how it would behave with 1 gen ECU I guess it won't work. Swapping cams/chains/phasers takes 3h - not worth the hassle.
    LSA is the same, no need to hack anything LOL
    Nov 2017
    Austin
    1,089
    In this Ford PDF, they sure make it sound possible:
    https://performanceparts.ford.com/do...rence_2-16.pdf
    Camshafts: The Gen 2 camshafts are 13mm lift
    on the intake and exhaust, which is 1mm of added lift
    vs. the Gen 1 Coyote. Gen 2 camshafts must be used with the Gen 2 chaindrive and phasers
    Chain-drive: The Gen 2 phasers , primary chain,
    and crank-sprocket are a matched set and cannot
    be interchanged with Gen 1 chain-drive. Also, VCT
    bolts are new for Gen 2 chain-drive due to bolt
    clearance to VCT solenoids.
    A calibration modification will be needed due to Gen
    2 mid-lock phasers
    • Chain Drive Kit PN - M-6004-A5015
