I go to the track and sometimes I forget to turn off the traction control
using the button on the center console on my 2000 C5. Can traction
control be programmed off with the Hptuner ?
Thanks >>>>> INTHERED
LINGENFELTER MAGNACHARGED 2000 A4 Torch Red Z51 Vert, Smoothline HT, LPE IC Magnacharger, Z06 cam, LPE CNC heads, CC RPM kit, LPE hood, Yank 2800, Rossler trans, Z06 rear w/300Ms, Chrome C6 Z06 rims w/PS2s, Z06 calipers w/PF carbon metallics , Eradispeeds, WCC screens, BBK 80mm TB, TB bypass, 160 TS, GM Z06 MAF, Blackwing, Corsa Pace, AR headers X-pipe & Hiflow Cats, GM HP wires, NGK TR6s, Hptuned by INTHERED with a best 1/4 mile of 10.87 @ 128.90 mph on BFG DRs
I relocated the traction control button on my 03 5.3 liter truck. I noticed that when the switch module was unplugged, TC appeared to be off. This may be an option for you.
No, it can't be turned off. However there is a device that is easy to hook up that will retain your last setting in TC. I just can't remember what it's called. Try a Google search.Originally Posted by INTHERED
Let me add a little advice. When you're at the track you need a routine. After a few sessions it becomes automatic and you won't forget. Here's an example.
Fasten seat belt.
Start engine.
Adjust seat position.
Shut off TC.
Roll up windows.
Good luck to ya.
Bob K
BoMar Racing
Rookie of the Year -Englishtown. NJ
Member - Panuzzo Racing
Member - NHRA
i agree routine is a definate if u bracket race. breaking bad habbits and making yourself do it time after time. practice it everytime u get in your car. u will be more consistant in your reaction times by having a clear head and good habits in practice.
98 Z28m6,ramVDS,lakewood LCA,sphon SFC,NOS 125shot,HPtuned LQ4.045milled heads,224/228 581/588 comp cam,fast toys lid,ported 85maf,ls6 intake,long tubes with custom exhaust
I have a routine but I also have a senior moment every once in a while.
INTHERED
SLP sells somethin to reverse the switch so it is automatically off when u start the car and has to be physically turned ON instead of off.Originally Posted by INTHERED
The traction control in electric throttle vehicles is a
lot more involved than the F-bodies. The "reverse
module" might work or there might be a 'vette version
out there.
There are some ETC traction control things you can
kill. On trucks and a year or more back I found these
under the DFCO tab. May have moved as things get
rearranged in the software, haven't been in that truck
for some time now. Killing these made some hellacious
improvement in throttle response / acceleration as it
quit holding back the throttle opening. This truck was
AWD on drag radials with a blower. Traction control,
phooey.
Thanks I will check it out - INTHEREDOriginally Posted by gold98Z28
Just went to SLPs web page and the TCS module is for F-bodies onlyOriginally Posted by jimmyblue
INTHERED
I found one. LapTrax TracActive Controller for the C5/Z06Originally Posted by INTHERED
http://www.laptrax.com/Products.asp
Bob K
BoMar Racing
Member - NHRA
THANKS >>>> INTHEREDOriginally Posted by Special K
You're welcome. I can't contribute much to this forum. I'm ignorent when it comes to tuning so it feels good to be able to contribute something.Originally Posted by INTHERED
Bob K
BoMar Racing
Member - NHRA
