Results 1 to 8 of 8
Thread: Can't get cam idle
    Sep 2015
    Greenwood S.C.
    9
    Can't get cam idle
    Got a 2007 Trailblazer SS that someone else tried to get off the ground. I know nothing about idle timing and can't really figure out what he done, which has me even more lost. Just wondering if someone could look at my as found and see if anything jumps out to you as to why and what I can do. Thanks
    13,533
    Can you be more specific about what you are asking?
    Does it not idle at all or are you asking why won't it chop at idle?
    For one the timing is set kinda avg at 22 degrees, that will make it pretty tame if the fueling is on point. The idle rpm is set to 850rpm, which is kinda high depending on camshaft design to make it chop.
    More information about what you are asking is needed, or even data logs to show what you are talking about.
    Sep 2015
    Greenwood S.C.
    9
    Thanks 5FDP, Won't idle at all. Have to pedal to keep running. It's just I don't understand some of the changes this tuner made or why and I'm a little scared to proceed. I know nothing here.
    Nov 2009
    All Around
    3,149
    jd blazer as found base MAS.hpt
    use attached
    your airflow models were not touches among other details
    Sep 2015
    Greenwood S.C.
    9
    Man yall fella's get up early in a.m. Thanks Sultan, going to get started.
    Sep 2015
    Greenwood S.C.
    9
    Quote Originally Posted by SultanHassanMasTuning View Post
    use attached
    Flashed and it idles good except, when I rev it up and let off it will die. I'm in process of setting all my timing histo's and such. in scanner. Very new to this "slow" but gaining. Thanks.
    Nov 2009
    All Around
    3,149
    attached a log here so we can know whats going on, its just an initial tune to get you started
    Sep 2015
    Greenwood S.C.
    9
    Could you tell me which parameters you need logged. Sorry for late responses, I've been on dyno all day. I have a mustang dyno and it's Friday. All the street boys are wanting pulls. I'll get it up as soon as I can get logged. Thanks again.
