I have been beating my head against the wall...
So, I blew up the LS1 in my personal 1998 Trans AM, replaced it with a 2004 LQ4 from a Yukon Denali and pumped it up with a BTR stage 4 truck cam. I really need some guidance, I have not trusted my skills to tune with HP Tuners on a customer's car yet, so I almost exclusively use FAST, FiTech or now Holley self tuning set ups to avoid this. I decided to pull the trigger on the HP Tuners on my own car and learn to tune it before I trusted doing it on a customers car. However, I have not gotten the damn thing to bypass the VATS system at all. I have bypassed the VATS system using a resistor, and then bypassed using the Hawk Motorsports bypass. Same old bullshit... still shuts down fuel pump and injector pulse at 3 seconds. I have double checked all grounds, all connections. No issues, I am thoroughly at a loss for words and beyond frustrated. I did not know that the write calibration and write tune was a seperate function and put in the write calibration first... could I have bricked the VATS programming? I have since rewritten and wrote entire but to no success. Please someone point me in the right direction????????? Also, I have seen that most people tell me to disable starter check and disable VATS 1 and 2 but its not present on my software 4.4.4 vcm editor with an MPVI2????
