2005 GTO Plug and Play Fuel Pump Upgrade
Guys,
FYI I'm running a Procharged 05 GTO with a Kenne Bell Boost A Pump on a stock pump. After checking, it was running out of fuel at about 6000 rpm. I did a little work and found a plug and play fuel pump from Deatschwerks. Their 340 lpm pump 9-309-1008 is a literally plug and play pump for the GTO fuel pump module. The pump is warranted for 3 years and will run upto 18v input without issue. My car now has AFR control to 7300 rpm.
Aaron
I also have a 05 gto, I have that same exact pump. I have a torqstorm blower pushing 10psi. The pump is drop in and i have no problems running my fuel injector clinic 72lb injectors 10psi up to 6500 rpm no running out of fuel and duty cycle is around 71% give or take if i remember. Car went 11.7 on 5psi with 133k on completely stock longblock. Just put the 10lb pulley on last month but never got to the track before it snowed here in ny.
