In my last thread, I got where I needed to be to log all the parameters so I could attempt to do my own shift scheduling. Here's what I've discovered. In regular, everyday driving, the Shift ID that my car is in 95% of the time is Shift ID 5. When I go into the VCM Editor, does that mean that if I want to modify the shifting pattern, I need to go into Transmission Shift Pattern 5?
Basically what's happening is, I have a Stage 1 package on my 392. There's a lot of stuff tacked on to the car now but at its core, it's ported heads and a cam. The engine is now making 600hp. While driving down city streets at less than 60mph in standard driving mode (not Sport Mode), the car is trying to shift up too high. You know how if you shift a manual transmission up to high and you're going to slow, the car jerks a bit but once you downshift you're rpms pickup but now the car is smooth? That's what I want to achieve.
In short, I'd like to modify the shift pattern so that when I'm slowing down or just gliding along at like 10% throttle, anytime the car hits 1,250 rpms, downshift. If I have 0% throttle and/or I'm applying the break, I'm OK letting it drop to like 1,100 rpms before it downshifts, like it's basically doing now. Am I on the right track?
