I have read all the posts I can find on the Pentastar. I have been tuning gm's for a couple of years now, but I own a 2014 Ram with the 3.6L. I have been working with it for a while now. I have made a few changes to improve throttle response, PE, fan temps, speed limiter, and adjusted for tire size. I am working with the VVT now. I've read that the WOT tables are good, but also that the numbers for NA should range from 105 to 130 for intake and 105 to 115 for exhaust. My WOT tables are not within that range. I was wondering if anyone would be willing to share their experience with these cams. I have made some minor changes and seem to feel improvement. I also read that these engines only use the p/t table, but my truck uses them all. I started with the normal table, then had to make changes to the TIP table, and then to the WOT table. It seems that smoothing the tables to have a low number of 105 would be a good starting point??? Thanks in advance, any advice is appreciated.
