Results 1 to 2 of 2
Thread: Injector Flow Rate
    Aug 2019
    9
    Injector Flow Rate
    When tuning for new injector is the flow rate table the rate of the injector itself or the flow rate at a given fuel pressure?
    13,598
    The flow rate at the given fuel pressure.
    Like 25lb/hr at 58psi or whatever.
    Whichever injectors you have should come with data, otherwise you'd be guessing at some of the data needed.
