So I have finally started my build! I went through and followed Chopperdocs youtube tutorial on tuning the ve. I went through and added 15% first and left the MAF and all turned on. That file as attached as first startup. Then I went and disabled all the things he suggested in the tutorial, Fail the MAF, disable STFT and LTFT(but I didnt see a LTFT on my tune so I just did STFT), disable DFCO, Disable COT, eq ratio to 1, hight octane to the low octane, set Pe to na build. then I ran it again and noticed at 800-1200 was really lean based off my Wideband. AEM is installed in my y pipe at the y and there is nothingf behind it. I have checked for exhaust leaks but dont see or hear any. When I saw it lean I added 15% more to the 800 and 1200 column. The log is attached for the one after that as well. My motor is a 02 lq4 that I put gen4 rods and flat top pistons in. it has a Texas speed truck state 2 cam and 799 heads. they have been milled .010 so the CR that I am assuming is 10.5 to 1. not sure if i should start troubleshooting the AFR gauge or if it was indeed really lean.
