Results 1 to 3 of 3
Thread: 97 Corvette MAP settings can be changed?
    1997 corvette has no way to change MAP settings? There is no option
    2008 Corvette
    UPP Twin turbo T4 67mm BB billet wheel kit
    427 LME Billet Setup
    Fore Innovations Triple 465 L4 Setup
    FIC 2150 injectors
    RPM TH400/9 inch
    Pro Torque Bolt Together Converter
    MaxxECU Stand Alone
    28,261
    They are only available for modification when the 2 bar custom operating system is applied to the operating system.
    I downloaded a 97 file with 2 bar map enabled and didn't see the option on that either. Have a 97 with a LS3 swap along with LS3 MAP in the intake. With key on it read 80KPA so it is sharing cruise areas with WOT causing lots of issues.
