Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 90
Thread: 2.0 tfsi
  1. #61
    Tuner 1970ss8.1's Avatar
    May 2016
    Napa, Ca
    151
    I tried everything, re-polled multiple times and not there.
    I am trying to figure out another problem in the gen 3 GM section right now. The Audi runs, on the other hand I just fired my chevelle for the first time and am having issues that I can?t figure out yet.
    Here?s a vid of the start up.
    https://youtu.be/K8DIimhBJK8
  2. #62
    May 2016
    Napa, Ca
    151
    They are working up a new update.
  3. #63
    May 2016
    Napa, Ca
    151
    Just got back from the holiday and hooked up to the car with the new update, and still a no go!
  4. #64
    May 2016
    Napa, Ca
    151
    Finally got my boost PID
    They gave me boots pressure and boost pressure request. I took a small log last night.
    My Avatar is my Wife and Proud of it!!
    1970 Chevelle SS 8.1 Vortec T56 9" 3.00
    2006 3500HD 8.1 vortec Allison 6sp 4.10 4X4
    2013 Audi A5 Cab 2.0tfsi Quatro
    www.mcmnapa.com
  5. #65
    May 2016
    Napa, Ca
    151
    Why would I have 14.9 psi at idle? Also my accelerator doesn?t match my TPS.
  6. #66
    Jul 2019
    Wilmington, MA, USA
    155
    It sounds like you're looking at an absolute pressure. Absolute pressure has its zero point at a total vacuum, so without vacuum or boost it'll read atmospheric pressure which usually is around 14.5 PSI at sea level, less as you go up in altitude. The fact it's reading higher than 14.5 means you may be looking at the sensor that's in between the turbo and the throttle body, and the pressure is > 14.5 because the turbo is generating a small about of boost. Or it could just be the atmospheric pressure was high that day.
    Re the TPS: as you probably know our cars have electronic throttle bodies. The throttle plate position will not always match the pedal position... in fact it rarely will. Plus the TB and the accelerator pedal both have two potentiometers on them. So you've got two measurements of pedal position which don't necessarily go from 0-100 because the electrical range is greater than the mechanical range and other aspects of the design, and the same is true of the throttle body. Then with the TB you've got "desired", "commanded", and "actual". I'm pretty sure VAG also throws in a few other random numbers with the word "throttle" in the description just to piss off people like us.
    For me the answer to the TPS question is just log every value you can find that appears throttle-related, then if you're lucky you'll find one that goes 0-100 corresponding to pedal position.
  7. #67
    May 2016
    Napa, Ca
    151
    Good info. Makes sense. Where I live we are below sea level so that is probably why it is 14.9. Should I set up a table and filter out the 14.9? The TB makes sense, but with GM you can tune the TB and Petal rate. I can?t find a table for this. Now that I can log boost I?ve been setting up the scanner differently and the load tables are starting to make sense to me. I just think it is weird that at 60% petal I have 85% throttle.
  8. #68
    Sep 2019
    ON, Canada
    346
    I would basically forget everything you knew about tuning in relation to GM vs VAG they are just such different systems that the knowledge hardly every crosses over.
    The reason you are getting WOT at 60% pedal is because it?s requesting enough cylinder filling to dictate a WOT request after you reach WOT filling request any filling requests higher than that are achieved with the electronic boost control solenoid (N75) with boost....
    The pedal requests an optimum torque value then the torque value translates to a load (cylinder filling)
    And yes the boost reading is from the charge piping so it will never go lower than atmospheric pressure because it never sees vacuum
  9. #69
    May 2016
    Napa, Ca
    151
    Is it normal for a stock 2.0 to have 30 psi of boost?
    Or does this have a tune already.
  10. #70
    Jul 2019
    Wilmington, MA, USA
    155
    In terms of absolute pressure, yes. About 15 PSI of atmosphere plus about 15 PSI of boost = the 30 PSI you're seeing. If you Google "absolute vs. gauge pressure" you can probably find a better explanation than I can provide.
  11. #71
    May 2016
    Napa, Ca
    151
    I understand, but why would the desired boost be 30 psi. Wouldn?t it desire 15 psi. Or does the desired boost take into account the atmospheric pressure.
  12. #72
    Jul 2019
    Wilmington, MA, USA
    155
    Quote Originally Posted by 1970ss8.1 View Post
    Yep, it does!
    You and I tend to think of manifold pressure (= boost) as vacuum/pressure relative to atmosphere. But engines function mostly in terms of absolute pressure, so that's what they use for boost control.
  13. #73
    May 2016
    Napa, Ca
    151
    What would cause me to be commanding 2.00 lambda when I let off the petal. Shouldn?t it be 1.00
  14. #74
    Sep 2019
    ON, Canada
    346
    Decel enleanment/cutoff
  15. #75
    May 2016
    Napa, Ca
    151
    Thanks Ill look into that. Ive been working on the scanner setting up some good tables. Take a look and see if im on the right track.
    www.mcmnapa.com
  16. #76
    Sep 2019
    ON, Canada
    346
    Just take a stock 3rd pull log and post it, that way we can see what you’re logging ��
  17. #77
    May 2016
    Napa, Ca
    151
    the first one is a third gear pull. My Petal still wont go over 90%
    www.mcmnapa.com
  18. #78
    Sep 2019
    ON, Canada
    346
    why do you need the pedal to register 100%?
  19. #79
    May 2016
    Napa, Ca
    151
    I don?t know. GM get to 100%. Just trying to figure out this ECU.
  20. #80
    Jul 2019
    Wilmington, MA, USA
    155
    Your engine is a little different from mine so might have different parameters, but look in the list for "Accelerator pedal position". That one goes 0 to 100% - see attached.
