Originally Posted by
Kyle_Customizer
It looks like you are having a similar problem that I was having when I started my 2016 Camaro. Looking at the file you are commanding 900 RPM idle but in the log it seems to be trying to run at 800 RPM. I don't see the commanded idle RPM in your log, but the idle does seem to be lower than commanded. My research on here shows people doing many things to correct it. What I had luck with was cutting the external load (all oil temps up to 1200 RPM) by 50% this allowed a stable idle and better drivability. To fine tune it, I subtracted 20 (just a number value) from 100mG to 600mG and up to 1200 RPM in the Torque editor. Then extrapolated (seems to blend the numbers on its own). Then subtracted the same value from the MAP table in the torque editor (30kpa to 70kpa up to 1200RPM) and extrapolated and then clicked calculate coefficients. If yours is still pretty far off, try 40 as a value to subtract. I can now idle at 750 with 17-18 degrees timing. It seems different operating systems require a different way of adjusting, so please post up what ends up working for you.
