So I have a question that has recently perplexed me.
During tuning on a cam'd gen 3 setup, as I was going through and adjusting the idle spark, over and under speed spark correction to get it to not surge and idle properly I had a thought.
On a carb setup, the idle air is metered by the throttle blade set screw, so it is constant.
Fueling is constant via the idle bleed set screws.
Timing is constant as well on a distributor setup.
In my previous experience with a carb setup/large cam, there really was no issue getting it to idle after adjusting those things. So, as a test, I used the scanner to command a set AFR, Timing and IAC position, yet the RPM's like to surge/swing a LOT, which got me to thinking, why? It's technically no different than a carb setup at that point?
The car runs perfectly once I got the spark over/under set properly along with fueling and IAC counts in the right range. Just was something that I had wondered the how's and why's on.
