Results 1 to 8 of 8
Thread: Pids for alchol e85
    Feb 2016
    482
    Pids for alchol e85
    are there any pids for E% for a 2019 mustang s550?
    I tried several
    Feb 2016
    482
    Bump
    28,247
    I know with my 2014 Mustang you need to turn ON flex fuel in the calibration for the pid to show in the scanner, likely the same on your vehicle.
    Feb 2016
    482
    Thanks will try now
    Feb 2016
    482
    Alcohol percent
    Ok tried Same computer but with GM. It works
    I switch to ford and it won?t even come up
    Feb 2016
    482
    I have tune in car and its running e85 -I just cant add alchocol % in scanner
    Apr 2018
    605
    I want to do this to my 2014 just to get a gauge of the ethanol content at my normal gas station. I've populated the Inference section and 'FFV' tables all over the tune with what I think is right but I'm not 100% sure it's accurate enough to flip the switch. Anyone have a guide or template to converting the stock tune to a Flex Fuel ready tune?
    Knock Retard is the reduction or prevention of knock by lowering ignition timing:
    (+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
    (--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
    __________________________________________________ ________
    2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
    Don't fix it if it ain't broken | Maximum effort gets maximum results
    Feb 2016
    482
    re-poll car and it started working
