car fired right up and idles perfectly. at first I would give it gas and it would burp and stall. would not climb in rpm. then slowly it seems to be learning. I could give it throttle and when I hit about 3,000 it goes into limp mode and no response from the throttle. I erase the code and can get one throttle response and it goes back into limp mode. now I can rev the engine over and over but If I go past 3,000 it goes into limp mode. I believe its a correlation problem between the pedal the tac module and the throttle body. anyone else have an issue like this? ill post a tune next week. we are loading it on the trailer now to head to sema. thanks in advance.
