Has anyone done a cat delete... not sure what it is that I am doing wrong but codes still show on the diagnostics (no check engine) but truck will not stay on while remote start!?!
does any one know the steps to folllow???
Post your tune.
Post the file and we can check it out.
Did you disable those codes that show up? Disable every code dealing with bank 1 & 2 sensor 2. Also the catalyst efficiency codes. Uncheck ses light and choose no error reported.
I set all the ones I found from bank 1 and 2 sensor 2 to (no error reported) do I need to Uncheck SES as well?
Thank you guys for junking in to help!
Yes, you have to uncheck the SES box.
Some codes are permanent DTC's that won't just go away, they may stop coming up after a while though.
