Originally Posted by
Ace120
I have an E78 that will not activate relay controlled fans. If I ground out the wires at the ecm the fans kick on so I know the hardware is all correct. When I command them on under special function, I get nothing. I have done a search and found some info here. my harness appears to be correct (pins 54 and 41). I know settings have to be changed (I already changed the fan type and number of fans) but does something have to be changed before the ecm will turn them on through the special functions menu?
