Results 1 to 8 of 8
Thread: 17 SS Tuning Aid
    Oct 2019
    3
    17 SS Tuning Aid
    Recently had my car "Pro Tuned", it's running same times as it was stock with all the mods and tune (1 7/8 headers Speed engineering headers & Xpipe, Rotofab dry intake, Flexfuel sensor) No TCM tune
    having some doubt about what this tuner has actually adjusted, AFR when cruising will flip flop from 13.5 to 15.0 every few seconds while on E85 (93 AFR stays 14.5-14.7) (WOT AFR 11.2-11.8 for both 93 and E85)
    If someone can help aid what to fix in the maps, or recommend a tuner that can help remotely.
    attached tune and logs from tuner.
    Aug 2014
    Central, LA
    403
    I have doubts that this car is running how it should based on what I see here. Do you have any wot logs? From your description of looking at your wideband it's way too rich, and the commanded lambdas in this tune are too rich as well. Hard to make much judgement without logs with a wb showing. Was your tcm tuned?
    Aug 2019
    8
    Sounds like your MAF sensor may not be calibrated correctly. Pray performance on facebook or Ted Jannetty at jannettyracing.com are both well known 6th gen tuners.
    Aug 2014
    Central, LA
    403
    Quote Originally Posted by wirthit View Post
    There are lots of other great tuners out there as well as on this board. We can help him here provided we get the right data.
    Nov 2009
    Jeddah, Saudi Arabia
    2,218
    you need to list more information and a datalog of your car as well
    E-tuning/remote Tuning Sultan@mastuning.net Follow @MASTUNING Contact/Whatsapp +966555366161
    [URL="http://www.mastuningsaudi.com"]
    Oct 2019
    3
    Pretty new to the platform and getting into the tune aspect.
    I have a few Logs on the computer he took, he also visually read the wideband not even using the function of the 30-334 WB i have...
    ill attach the logs to the main post if you have any recommendations what exactly I should log would be helpful
    Oct 2019
    3
    I attached a log from what he had saved on the computer, what I should log would be helpful. tcm is untouched
    Aug 2014
    Central, LA
    403
    Its commanding a fat EQ, probably running even fatter, short shifting, and taking a minute to shift.
    Shoot me a PM. I'll send you a config to take logs with and we'll make you faster.
