Vehicle is a 2006 ctsv. (1st gen ctsv with slightly older e67). It's a manual.
Long story short you'll see on launch in 1st gear, that my foot has the pedal to the floor the entire time, yet the throttlebody decides to close.
You can also clearly the clutch is slipping. 6500 in 1st should be 48MPH in the log. you'll see in 1st where it goes 22mph at 6500 RPM (tires NOT spinning).
In the tune, all tq management / tcs etc is disabled. Infact the brake pedal pressure sensor to ABS is D/C (vehicle screen says traction control is disabled in car) + disconnected 1x hub in the front.
Why is my stupid throttle closing? What is missed? I do realize the better solution is to clearly fix the clutch. That is happening. But i cannot have the throttle closing on launch. Period.
